help with projector diy lighting
I ordered a bulb of YWH but it failed to work in my projector, not sure why, suspect the ballast. I want to make sure the projector is working ok before I spend any more money. If I bypass the lamp detection, can I use a cheap light source to make sure there is not a more inherent problem with the projector optics etc.
I have a Plus U5-132 Projector, Replacement bulb was a 200w BSM-AC.
Thats a pic of the insides, can anyone help me with finding the wire to bypass lamp check.
thanks
