in other post the member YWH told me this explanation above;
The start volts is about 5-15KV, work volts is about 60-80v.
need a ballast to run it. not contact how volts only.
I have the burner, you can rebuid your lamp.
http://www.diyaudio.com/forums/attachment.php?s=&postid=1641604&stamp=1225022102
now i need know, how i can rebuild my lamp?
I see the picture of lamp and i want know what you wanted to say with "not contact how volts only?
this picture the is lamp is damage? my lamp is gray on the midle(on buble )
when lamp is good ís possible see into the bubble or is gray like picture?
the 5-15kv you wanted to say 5- 15000 volts?!!!!!???
sorry my english and many questions my friend, is because this lamp dont start anymore and other things is working normaly(the led lamp indicator stay flashing) .
Thanks for help
Thanks for help
yes!
need 5000-15000 volts when it start, and than down to 60-80v when work.
you can cheack " how about start matel halogen lamp."
the ballast can do 5000-15000 volts start, and 60-80v work.
