Help with first Speaker build atmos speaker
Hello everyone! I need YOUR help. I'm trying to design an atmos speaker that goes in the corner of our tv room. It's my first speaker build.
I would like to use the CNote Drivers and perhaps even the same crossover.
Explanation here.
Also, if it is adviseable to use the Cnote drivers, how do I go about figuring out how to space them (the holes for the drivers on the baffle) exactly as they are spaced in the Cnote?
2021-11-10 15-59-19 on Vimeo
The crossover should work fine for those drivers.
But, the C note is ported, you say your cab isn't ported??? - if you don't port, you'll lose bass, (if you need it); if you do port, you'll need to calc. a new port length for your box volume.
Working out the volume, just take the average of the long side and short side at the front and work out your volume from that....
