I am trying to find some Mylar for Magnetic planar build.
Can any of you guys help with a source,also what is the best thickness.
Thanks,
Thanks,
Mcmaster.com internet hardware store in Cleveland, cadillac plastics, local stock plastic distributor in big cities.
Are you talking about this,I am not sure about how thick I need.
McMaster-Carr
Scott
I know its still available. It used to be used in RCA TV transmitters to repair the 5762 tube sockets after the got hit by lightning.
I just ordered this:
http://cgi.ebay.com/Electrostatic-Speaker-Membrane-Dupont-Mylar-C-6um-40M-/
280533663465?pt=Vintage_Electronics_R2&hash=item41511bfee9
Good service and fast delivery ... and quite cheap 😉
Also look at this thread
http://www.diyaudio.com/forums/planars-exotics/182534-sources-mylar-similar-film.html#post2458201
I think that 6 um is a good compromise ... how low do you intend to go?
That is just what I was looking at, I would like to go to 40hz if possible.
Thanks,
Aluminum foil Tape?
Any leads on the aluminum foil tape,I found it in the states
but it is back ordered.
If you are going to make larger bass panels (which will be needed to go to 40) you should/could consider using 12 um.
6 um I think is a good compromize for broad band mid to high. For a real tweeter section 3.5/4 or even 2 um would be even better.
(seems my last link to ebay don't work ... cut in half 🙂 )
See here the selection
http://stores.ebay.com/music-in-life/_i.html?_fsub=845047013
music-in-life items - Get great deals on Electrostatic Speaker Mylar C 2um 40M Elvamide 60g items on eBay Stores!
Thanks for the info.
- Planars & Exotics
- Help with finding Mylar film.
