Help with filter for dipoles
Some time ago I built fullrange dipoles using Dayton 15" IB, seas P17RCY and NEO8.
15" lp with 48dB at 30hz and hp with 48dB at 290hz(active crossover)
Seas lp with 6db at 290 and hp with 6dB at 1400hz(passive)
Neo8 lp with 6dB at 1400hz(passive)
Now I'm going to replace the seas 6,5" with Dayton RS-108S-8 7"
I've been told that I can't use the same crossovers as now due to ringing from the Dayton 7" at around 6000hz.
Would this 12dB crossover at 1000hz work for the dayton 7" and the Neo8?
