Help with Diode A2 identification
Good afternoon
I'm working on a Sundown Salt 400.2. The output section is damaged. 2 diodes marked A2 are toast. Is this a 1N4148 diode in SOD123F package? It measures 1.75mm x 1.25mm and has the flat narrow leads. The data sheet I'm looking at lists the 123 package much larger.
They were connected to pins 1 (VAA) and 6 (VSS) of the IRS2092S. Locations D7 and D8 in first pic. 2nd pic is of other side. Easier to read the diodes.
Thanks in advance!
