Hello!
I am currently building a big boombox with this setup:
2x http://www.ljudia.se/hogtalarelement...hp-10w-p78414/
4x http://www.ljudia.se/hogtalarelement...-1005-p581196/
1x http://www.ljudia.se/hogtalarelement...327awd-p78464/
(Maybe) 1x http://www.ljudia.se/hogtalarelement...10-8r-p716594/
Not sure if I will use this mid speaker or not)
The amplifier I am probably going to use:
http://www.ebay.com/itm/4-X-100Watt-...item51b941766b
I am a total noob on the crossover part, but I understand that I will need it to not destroy my speakers and to make it sound better.
What kind of crossovers do I need? A guy told me I should have a active Crossover... So what are my options and how will I connect everything?
Thanks!
Thanks!
Buzzy, anyone can throw some drivers into a cabinet. The crossover is the hard part, and a 4 way PA speaker would be a huge amount of work. It might not even sound any good at the end of it.
No-one is going to do the work for you. Sorry. 🙂
FWIW, here's some links that might suggest where to go:
http://www.eminence.com/
http://www.bluearan.co.uk/index.php?manufacturer=Eminence&masthead=Passive_Crossovers&subheadnew=2_Way_Crossovers
Hey!
Thanks for the reply.
I understand the problem and maybe I should change the setup to:
4x Diskanthorn - Monacor MPT-016
3x P.audio HP-10W - Ljudia - Multimedia Hemelektronik Karaoke PA anläggning DJ utrustning Ljus utrustning
2x Celestion TF0615MR 8R - Ljudia - Multimedia Hemelektronik Karaoke PA anläggning DJ utrustning Ljus utrustning
Then I should have a 3way system instead of 4way right?
I have read a little bit more about crossovers now and lets say I have this new setup and make a 3way crossover with:
Lowpass 2000hz for the 10"
Highpass 6000hz for the Treble (Tweeters)
What about the mid how does that work in a 3way? Do you have booth low and highpasses?
Thanks!
