I am trying to add a PCM1792 to a Sony CDP-391. From what I have found this is putting data out in Standard (Right Justified) format and read that the PCM by default accepts I2S.
I was wondering if I could get some guidance on how to setup an arduino to change the settings of the dac. I am not familiar with the SPI interface.
Any help would be appreciated.
Thanks for the response, seems like I2C is the way to go instead of of SPI. Since I have never done any type of serial communication like this I need to find some more code examples. I was able to get SPDIF working today on the player im modding so that makes me feel good. Now to get this working.
Ok I make some headway but still having issues but hopefully somebody can help me out.
I got everything hooked up and was doing a serial.print to display the ack and I tried reading the register and some times it would be the right data along with the ACKs being 0's.
But some times I get errors. I have crystal from the DSP in the CDP going to the clk on the new DAC and im using an arduino to communicate to the DAC. I think my issue from here is syncing the arduino to the DAC and clk of the DSP.
Any ideas on what to do?
In general
1- You set certain pins to enable s/w mode in the DAC.
2- Then after connecting the Arduino I2C to the DAC's I2C pins (making sure either that your DAC is 5V tolerant or by using a level shifting to convert 5V to 3.3V), You can start writing values to the registers of the DAC.
3- After power up, wait a little bit in the Arduino before starting writing values into the registers.
4- Try writing only to the registers you need to configure. At power-up, registers reset to some default value and if you don't need to change those values, don't write to them. Some registers are write only, some read only.
arduino.cc has a lot of examples on how to use the libraries.
BTW, I've never done any kind of programming of this sort, so I started from scratch, If you read my blog starting from the oldest post, it should give you some idea as to where I found relevant information to learn how to program the Arduino.
Hope this helps.
Hope this helps.
