I am about to commence a TABAQ build with the 8 ohm Faital 4FE35. The response graph attached shows the well known breakup at about 8kHz. This is all very new to me and would appreciate if I can get some confirmation that I'm on the right track. I know alot is personal preference but i'm ordering the speakers and thought I might include some on the components for the filters at the same time.
I was planning on using a BSC 3.9ohm + 1mH parallel in series with the +ve speaker connection.
I'm also thinking that a notch filter might deal with the 8kHz peak. This is where I could do with some help.
I'm a bit confused by the calculators - do I want an RLC filter?
Can anyone help with the values?
Does it go on the speaker or amp side of the BSC or doesn't it matter?
Other option is to use the 4FE32. It is more expensive but the peak is a bit less at 8kHz. If it didn't require the filter then the savings in the cost of the inductors would justify the extra cost of the speakers.
