Hello
I live in Brazil, and I love the Rockford fosgate amplifiers.
I always do a lot of research here in this forum, but I registered here in your forum recently.
I am restoring two old Punch 400.4 (1997), and I do not find much technical information about them. I need to adjust the BIAS current, but I can not get correct information about it. I just need to know which adjustment procedure, or some technical manual that contains the voltage and current values, necessary for me to adjust the Bias.
I found a topic here, which says to set from 4 to 5mv on top of one of the 0.1R resistors. I adjusted this way, but the amplifier generates a lot of heat, and a 2A consumption at rest, which I found quite high.
I could not find the amplifier service manual.
Sorry for the writing! haha
5mv is commonly suggested but as you found, it's too high. This is how I set the bias:
http://www.bcae1.com/temp/ausettingbias.swf
Thanks for the quick response!
In this case of the link, do I need an analog ammeter?
I have digital ammeter on my test power supply.
With the 4 channels set at 5mv, the amplifier consumes 2A idle.
In the 400.4 user's manual it does not say idle consumption. Would you have this information?
Thank you!
Thank you, I'll follow your procedure.
Here in Brazil, we do not have much information about these amplifiers.
Download this:
http://www.bcae1.com/temp/RFG-1400A.zip
Thanks a lot for the help!
Exactly this I needed, now I have manual, schematic and test procedures.
And really, in the procedures is recommended 50mA (5mv) per channel, but I'll leave a little less. I tested with 4mv, and the exact consumption is 1.8A.
Thank you.
I design quite a few of my own amps so there is no bias setup routine.
So I apply a sine wave to input and monitor output on a scope.
I turn up bias slowly until crossover distortion goes.
Quite often the bias current is as little as 10mA.
On quasi amps I often find zero bias current gives no crossover distortion.
1mv is plenty.
Yes it's true
I think it depends a lot on the design of the amplifier.
I do not have scope, but I would like to take this test on fosgate punch.
- General Interest
- Car Audio
- Help with Bias current Rockford Fosgate Punch 400.4
