Help with Adjusting Car Amp/Subwoofer
Hello, everyone! I need some help with adjusting my amplifier and my subwoofer. So, here's my equipment:
Head Unit - Pioneer DEH-1901UB,
Subwoofer: Kenwood KFC-W3514DVC
Amp: Kenwood KAC-6203
The thing is I'm not satisfied with the bass comming out of the trunk when I'm driving. It just feels weak. I would ask you for some help with setting it up properly.
Here are the settings:
The head unit has few options for subwoofer control:
Sub.W Ctrl (LPF settings): 80hz/-12 slope
Subwoofer phase: Normal
The EQ is flat and the preoutput (SLA in the HU menu) is 0 (-4 to 4 available)
My amplifier has only two control - A LPF switch and input sensitivity control. The LPF is switched to ON (according to the manual this sets LPF to 80hz - it cannot be changed - and turns the bass boost feature on, respectively, if it's set to off the LPF is off and the bass boost is off, too). So, I've switched the LPF on and the Input Sensitivity is set to 2 (5 min and 0.2 max available, here's a photo Google Drive: Sign-in).
In the manual of the amp is said that the Input Sensitivity have to be set according to the pre-output level of the center unit but I didn't quite understant that.
Here is the amp manual: http://manual.kenwood.com/files/B64-3356-00_00_M_English.pdf)
And here is the head unit manual: https://catalogs.pioneer-car.eu/Manuals/DEH_1901UB_QRD3378_manual/GetPDF.ashx
I'll be really glad if someone help me!
