Hi ,
I really need your help in building my first amplifier ...
I want a 2 x 100 W 8 Ohm Tube amplifier .. or less .. i don't know ...
Please .. please .. help me with the schematic and all the info ... transformers in special ... i need help in makeing them ...
This is my first tube project ...
THANKS !!!!
THANKS !!!!
100 watts... WOW! You must have really inefficient speakers.... or is this for a big Professional installation? My first amp is 4 watts SET, and with 93 dB speakers, I'm pretty happy with it. I can't imagine needing more than 10 or 20 watts!
Meh. I could go for 50-100W. Too bad it'd blow these speakers. -->>>
So yeah, 100W ain't easy, tube or solid state. You might be able to find a kit for like $500 or more but if you're commited to building it yourself, you WILL be starting smaller.
Tim
Tim
Only one?
Have a look under KT88, 6550, EL34/6CA7, etc. :
CLAUDIO BONAVOLTA
Cheers,😉
Give an example .. a schematic please
Only one?
CLAUDIO BONAVOLTA
Cheers,😉
Hmm ...
How i can make my output transformer ?? Wind it myself ...
Hmm .. maybe a simple 10 W design 🙂 i don't have the knoleage to build a 100 W one ..
A simple and good low power schematic ??
Thanks !
Thanks !
here's one for up to 70W depending on setup. but it can be expensive depending on wich parts you use.
http://www3.sympatico.ca/r.godmaire/VDV3070.htm
but as the other guys told you, do you really need 100W???
Ah, that's better. 😉 You can start with a 6V6 SE or PP amp, such as Revision 3 or Frankenhouse, detailed on my website.
Tim
Tim
do you really need 100 watts?
probably, if you're going to drive Magnepan or B&W Nautilus. i have two friends who uses those speakers. the B&W is driven by a 100wpc Jadis and the Magnepan is driven by a 150wpc Audio Research.
another friend has Sonus Faber Electa Amator II and is driven by a Conrad Johnson 75wpc.
then i have this friend who drives his Sonus Faber Guarneri with a 300B 😱
try this one. only about 3.5W but accoring to most people that should be enough depending on your speakers. AND it's quite a good manual for a first-timer 🙂
(still havn't built my first....waiting on paycheck) 😀
http://www.boozhoundlabs.com/howto/
Im building up about 5w stereo amp with 6v6's and 12ax7.
Heres very simple schematic: http://www.diyaudio.com/forums/attachment.php?s=&postid=378471
But if you have already chosen which scheme, plz tell us about it! 🙂
Cheers!
Cheers!
- Tubes / Valves
- Help .. tube amplifier .. 1st !
