help to calculate box please
Hi, I'm Ricardo from Chile and I need to ask for help, I want to make a 2-way system with my speakers (they are car), and I tried winisd but I don't understand the program much, I need to know what would be the optimal measurement for the speaker,I will leave your specifications. the other question is if I can use the crossovers that come in the kit or do I need to make exclusive ones for these boxes?, I hope you can help me, greetings.
The Elate SW 6 is a car mid/bass driver which would suit a sealed enclosure.
I would experiment with strong cardboard boxes of 30 to 40 litres in volume to see how the driver performs in them before committing yourself to actual woodwork.
It's not a subwoofer really, having a highish free air resonance of 50 Hz, and I wouldn't try to tune it in a ported enclosure.
thanks Galu for your help
Nominal Impedance: 4 Ohms
Power Handling: 180Wrms
Max. Trans.Pwr Handling: 1000Wrms
Sensitivity (2.83V/1M): 88dB
Frequency Response: 30-4000Hz
Resonant Freq. Fs Hz: 43
Voice Coil Diameter: 75mm
Voice Coil Height: 0.57in (14.50mm)
Voice Coil Type/ Former: Aluminum
Voice Coil Wire: Hexatech Aluminum
DC Resistance: 3.6 Ohms
Voice Coil Induct. @1 kHz: 0.41MH
Magnet System: Double Magnet Rear Vented
HE-Magnetic Gap Height: 0.20in (5mm)
B-Flux Density (T.M.): 0.66
BL Product/BXL: 5.37
Max. Linear Ex./Xmax: ±0.2in (±4.75mm)
Suspension Compliance CMS - mm/N: 0.81
Electrical Q Factor QES: 0.57
QTS: 0.44
QMS: 1.87
Mech.Resistance RMS - Ohm/meter: 2.41
Moving Mass MMS - gr: 16.9
Equiv. Can Air Load VAS: 16.02L (0.56cu.ft)
Effective Piston Area SD: 119sq.cm (18.45sq. inch)
Cone Type: One-Piece Formed
Cone Material: DPC
Unit Diameter: 6.5in (165mm)
Mounting Depth: 2.4in (61mm)
Mounting Cutout: 5.55in (141mm)
Net Weight: 2.6lb (1.18Kg)
With qts 0.44 you can do enything, sealed and ported even tl, I would go sealed in 20/25l. Nice midwoofer.
I'll leave the parameters written.
6" woofer specifications:
nominal impedance: 4 ohm
power handling: 200w
max. trasient power handling: 1000w
sensitivity (2.83v/1m) 89db
frequency response 25-4000hz
fs 50hz
voice coil diameter 75mm (3")
voice coil height 14.5mm (0.57")
voice coil type/former aluminium
voice coil wire hexatech aluminium
DC resistance 3.7ohm
voice coil inductance @1khz 0.38MH
magnet system Hybrid Rear Vented
HE- magnetic Gap Height 6mm (0.25")
B-flux density 0.8T
BL product/BXL 6.35
Max Linear Excursion/Xmax 8.5mm (+_ 4.25)
suspension compliance CMS 721
mechanical Q factor QES 0.39
Total Q factor Q/T 0.33
QMS 2.06
mechanical resistance RMS 1.033 KgS
moving mass MMS 13.56gr
equivalent cas Air Load VAS 14.35 liters
effective piston area SD 119cm
cone type one piece formed
cone material DCP (damped polymer Composite)
unit diameter 165mm (6.5")
mounting depth 61mm (2.37")
mounting cutout 141mm (5.55")dia.
net weight 1.180kg
