Need your help for my project. 4 or more TDA 1541A in balanced mode
Some informations
First PCB
CS8414 receiver ( 2 separates regulations with TL431)
Recloking with HC4040 (TL431). Accordind to Douma schematic
X0 clock 2.882 (Jung regulator)
Split I2S with HEF4517 from Philips (Guido advice) according to Pedja schematic
Dem Clock with HC161 according to Ecdesign schematic (TL431)
Buffer 74HC125N (TL431)
Don’t pay attention to the value of each componants and sense of capacitors. It is “home made pcb” without printing
All is working very well; j have tested it with 2X 12TDA1543 in // with Rikken and 20UF PIO;
Near the receiver you can see a connector for a daughter board in order to test several systems in order to play with spdif (transformes, …)
Second PCB
The design offer me the opportunity to add, like a tower sytem many pcb in order to have 2X 1,2,3,4, … TDA 1541A in //
At the oupout, j have already a D1 Jfer. Maybye a low pass filter in the future
My questions , before making the pcb ….
1. Pin 18 and 13. Decoupling caps
J do not understand why only these 2 capacators are different from the others. It is what j have seen on Pedga and Torsten Dac ?
J have done the same .
2 Usually pin 2 and 4 are connected together for BCK
On the “Dac.zip” from Guido , BCK is Pin 3 and Pin 4 is connected to pin 5
http://www.diyaudio.com/forums/showthread.php?threadid=8614&perpage=25&pagenumber=1
J do not know what to do ?
2. Power supply
J have read the “thread “more info about TDA”, but j haven’t enough knowledge in order to understand the conclusion.
+ 5 and -5V are decoupled from Dgnd
- 15v is decoupled from A Gnd
It is what j have done.
Thanks for your help, excuse for my poor English and knowledge.
It is just a mixing of several schematics, thanks to all guys for informations.
Some informations
First PCB
Second PCB
2. Power supply
This is the pcb without digital ground plane in order to see the design
No chance, j have read on a topic from Guido tent that the "star ground" wasn't à great conception.
j am lost
If someone had a layout example, it would be great ...
