help!..just a newbie
i just bought this vintage Denon Sa-3350 int amp dirt cheap...i cleaned the insides, sprayed contact cleaners on the pots and recapped the power filter caps...i was test running it for about a 2 hours when i smelled something like a burnt rubber, i opened it up and the power transformer was kind of hot...turned it off...let it cool a little bit, i tried turning it back on..no dice...now no more power...there's no busted fuses, no burnt resistors...
does anyone have a schematics or service manual of this amp?...or anybody can point me in the right direction?...
ola!
just an update, i had the transformer rewinded back home in the philippines, the secondary windings was grounded...had it fixed, now the denon SA-3350 int amp is working perfectly...
the power transformer...i had the wires labeled properly before cutting it plus so that i can solder it back correctly....costs me about $8 only for the rewinding...
its alive!...Denon SA-3350
Uploaded with ImageShack.us
thanks for the tip guys!...
