I got this woofer Dell (Zylux) A525 from a friend without the satellite speakers.
It has for connecting the speakers a DB-9 Connector, which is also used to turn the unit on/off.
here is the pinout of the DB-9 connector
i know how to put speakers on it and connect input source. But i dont have any idea how to turn it off. It has something todo with Pin 6 (ST-BY standby ?) and Pin 7 VC (Vcc ?)
it uses the IC
TDA8947J
i have taken some screen shots of the board will post them tonight.
here are my questions.
1. how to turn on the woofer. Should i ground the Pin6 or should i short it with Pin 7 (vcc)
2. The circuit has two ground types
pin 1 is G
Pin 4 and 9 are PG
which ones are used for what purpose ? audio input with pin 1 G and output with PG 4 and 9 ?
i dont want to burn the amp/woofer so did not try to short them.
any help will be appreciated
Code:
Pin 1-G
pin 2-R in
pin 3-L in
pin 4-PG
pin 5-R out
pin 6-ST BY
pin 7-VC
pin 8-L out
pin 9-PG
it uses the IC
TDA8947J
pin 1 is G
Pin 4 and 9 are PG
You can find the DS for TDA8947 online and it'll tell you what you need to know about how to mute/unmute the various channels. The chip has three ground pins as far as I recall - signal ground and two for power ground. 'G' is presumably going to signal ground and PG = power ground.
I am not that big of expert, can just solder things, dont understand what they do and how they work. I already took a look at Datasheet and here is the relevent portion.
cant paste the table in the right way.
i will post pics of the pcb as it has some components connected to the mode select pins.
the Mode1 and Mode2 pins 5 and 10 are already connected (shorted) on PCB i will post the pics and will try to track the paths and will identify the components along with way.
Code:
Mode selection
The TDA8947J has three functional modes which can be selected by applying the proper DC voltage to pin MODE1.
Standby — The current consumption is very low and the outputs are floating. The device is in the standby mode when VMODE1 < 0.8 V, or when the MODE1 pin is grounded. In the standby mode, the function of pin MODE2 has been disabled
Mute — The amplifier is DC-biased, but not operational (no audio output). This allows the input coupling capacitors to be charged to avoid pop-noise. The device is in the mute mode when 4.5 V < VMODE1 < (VCC - 3.5 V).
On — The amplifier is operating normally. The on mode is activated at VMODE1 > (VCC - 2.0 V). The output of channels 3 and 4 can be set to mute or on mode.
The output channels 3 and 4 can be switched on/off by applying a proper DC voltage to pin MODE2, under the condition that the output channels 1 and 2 are in the on mode
Voltage on pin Channel 1 and 2 Channel 3 and 4
MODE1 MODE2 (sub woofer)
0 to 0.8 V 0 to VCC standby standby
4.5 to (VCC - 3.5 V) 0 to VCC mute mute
(VCC - 2.0 V) to VCC 0 to (VCC - 3.5 V) on mute
(VCC - 2 V) to VCC on on
Here are the pics of PCB
Connecting pins 6-7 should turn on the amp.
Pins 2-3 come from a preamp/volume control in the satellite speaker, with pin 1 as ground for preamp and signal.
Pins 4-9 are most likely speaker return grounds.
Pins 5-8 are + speaker output to the satellite speakers.
