Well, I was unemployed for awhile and decided that making speakers would be cool. So i chose John's Tangband W3-871as a fun project. Well I got as far as making the enclosures and getting the speakers..
I am now working full time ( plus some heavy overtime) .. and I dont have time to research the parts needed for making the notch filters...
On John's site , this is the info Ive found.....
0.7 19ga air core
6.8 ohm 10w non inductive
8.2 mfd poly.
Unfortunealy the only things i can find are from Madisound. (It sounds like its important to maintain consistency with his designs.. So im wondering if there are some exact manufacturers to look for?)My goal is to finish the project as quickly as possible... Anyone know where i can find all these parts (plus PCB) .... ? Maybe even already assembled?
Any help would be greatly appreciated.
scott
0.7 19ga air core
8.2 mfd poly.
scott
Assuming you're not actually in Uganda the parts from Madisound should be fine. The described parts are fairly standard values and construction. An alternative would be Parts Express although you'd probably get the 20awg inductor. Standard wire wound ceramic resistors and Solen caps should work well enough. For a board you could go to Radio Shack and pick up some plain perf board.
thanks
Thankyou for taking the time, Ill move forward!
cheers
scott
p.s. Im not in UGanda... I just wanted to see the flag... 🙂
cheers
scott
Re: thanks
You're welcome. It is a very colorful flag. 🙂
yepper said:Thankyou for taking the time, Ill move forward!
cheers
scott
As reinforcement-- I built the same speakers and purchased the parts for the notch filter from Madisound. Works great and Madisound is great to work with.
There. Ended sentence with a preposition. Take that, English grammar!
Kofi
Kofi
