Help please on F5 build.
Hi, I am in the process of building an F5. I just tested the power section and my results were odd. First problem. When it is plugged in it is on. The on off switch has no effect either way. I am almost certain I wired the PEM wrong. Second problem, one channel produces 26.3 volts. The other produces one. So, is it the switch problem or maybe a bad solder? Any other ideas?
I am not an electronics pro. I have build ACAs and a bottle head quickie successfully in the past. Help is welcome.
Thanks!
Okay, What I need is a good diagram or photo of how to wire the PEM. I have a double fuse PEM that came with the hardware kit for the deluxe chassis from the DIY audio store.
