Hi all guy´s. I want anybody can explain why a non inverting amplifier has a zero at the unity gain crossover point and why inverting doesn´t have it. I could´t find any good explanation at google. I had read it at the article "on RIAA Equalization networks" but I couldn´t understand why. Is there any pdf in which this fact is clearly explained??
Best regards. Thanks in advance.
Osvaldo, from Barrio Garay, Almirante Brown, Buenos Aires, Argentina.
For RIAA equalization, you want the gain to decrease as frequency increases. However, with a non-inverting opamp circuit, the gain can not be less than one. So as frequency increases, the gain will reduce until it reaches unity, then level out, instead of reducing further. That gives the extra unwanted corner in the frequency response.
In the simple circuit below: Gain = (R1 + R2) / R1
Whatever values you choose, you can't make the gain less than unity. (For RIAA equalization, R2 would be replaced by an RC network)
AH, OK, very thanks. I think that there was a frequency rolloff inside the amplifier itself.
