Help needed with transistors 2SD147 and D313
Hi there.
I got an AKAI X360DS reel (transistorized) from the 70s that quit its job. The (very old) motors suddenly won't start any more. In particular, one transistor in it gets extremely hot to the point when it smokes and is about to burst out in flames.
This transistor is an old 2SD147 (TO66, its like a small hat. TO3 is a big hat) and no more available. I found a D313 (TO220) as a replacement for it. Now, what would be the correct pinout of this 2SD147?
I think I might be able to adapt the D313 with a little advise.
BTW, a matching service manual isn't freely available on the internet.
2SD147 pinout.
TO-220 will sort of "plug into" a TO-66 socket. Trim the collector lead, and bend the base and emitter at 90 degrees - right where the leads change width. Connect the collector tab to the mounting hole with one of the screws from the TO-66. It will fit comfortably in *one way*, which is the correct one. The wrong way is too tight a fit.
A transistor getting too hot is usually just a symptom that something *else* is wrong. A transistor won't get hot unless it's actually *working*. It's a good idea to replace one that has been badly stressed, but if you don't find out why it will do it again.
Took some time but here I am again.
By "motor run caps" what do you exactly mean?
I checked the schematics (I got them now) and the caps for the power supply aren't that hard to find. Since chances are that the mechanisms of the motors (rubber bands, rubber transmission wheels and brakes) are dried out, I think that using the preamp of this reel deck could be quite interesting so I'd just need it to engage into REC mode.
Of cause I'll also have to change some caps on the preamp section.
