Help needed with Ian Canada DAC
I bought the flagship DAC project from Ian Canada. Gabster's YouTube videos were very helpful putting it together but I need help connecting power. I'm using two Hammond transformers and I've confirmed with a DVM that I'm getting 3.3 volts from one LinearPi Pro, +/- 5 volts from a dual LinearPi Pro and I have another LinearPi Pro that I'll use to power a Raspberry Pi with +5 volts once I get the DAC working.
For the default setup of this project, where do I need to connect the different power wires? Should I use the output from the separate LinearPi Pro for +5 volts somewhere or do the +/- 5 volts wires provide that voltage?
Thank you,
-Robert
