I recently had a relative pass away, and I'm helping to sell off his audio equipment. One of the items he had was a pair of Audiostatic ES100 speakers. I know they need a power supply for each to operate, but I could not locate them. I've tried reaching out to Audiostatic without success.
I'd like to purchase new power supplies, can anyone tell me what I need to order?
... One of the items he had was a pair of Audiostatic ES100 speakers... I know they need a power supply for each to operate, but I could not locate them.
What country are you from?
If you live in the US, you will need a "wall-wart" type power supply with 120Vac input and 12Vac output(100mA - 200mA).
This is not a common product as most wall-warts output DC voltage, not AC.
Two that I have used are:
STANCOR, Model STA-3512E
TRIAD, Model WAU12-200
WAU12-200 Triad Magnetics | Mouser
Neither one of these has the correct connector on the end to plug into the ES-100.
You will need to cut off the existing connector and replace it with a 1/8"(3.5mm) phone connector.
Something like this:
1/8 Mono Phone Plug (2-Pack) : Phone Plugs | RadioShack.com
