help needed to fix amp!
i bought this amp as a blown "project", and the input nulling turoid was burnt (see pic) so i replaced it from a spare from a working amp and now i have power through out the output stages but still no led's are lighting up. any ideas what i should do next? i have the other identical amp on the work bench for referance if this will help me. the amp is a phoenix gold ms2125.
Connect the black lead of your multimeter to the ground terminal of the amplifier. Set the meter to DC volts. Apply power to the amp including remote.
Read the voltage on each lead of the power supply FETs. They're all likely to be the same. Post the readings.
Post the part number on the PWM IC (TLx94, SG352x) and measure the voltage on all pins. Post the readings for all 16 pins.
right, there's no voltage at any of the 16 pins on the pwm's. on the good amp they vary from around 2-12volts.
on the power supply fets, think i'm doing the right ones (4x irfp054 on each side). i have 12volts on the middle leg only. on the good amp i also have around 0.7volts on the left leg, nothing on the right.
hope this info helps!
hi
Check voltages at the mosfet legs again. The very left leg of the FEt´s are connected to small resistors, usually something arounf 10-100 Ohms. The middle legs are connected to the transformer coils. As you can see, each transformer uses 2 primary coils. So that totals up to 4 primary coils. As there are 8 mosfets, 2 mosfets work in parallel to drive one coil. The other end of the primary coils are connected to +12V . As the coils are very low in resistance, you get a 12V reading with your meter/scope.
The very right leg of the fets is connected to GND. Also check the main GND- curcuit line for burns and cracks.
I think you should start the other way around.
Even if the PWM-controller IC doesn´t work doesn´t have to mean it is broken. Your amplifier is a huge baby and it has more than one protect curcuits. It could also be a broken protect curcuit that will cause the PWM controller not to start.
Usually if there hd been a fault in the SMPS it is a good thing to take alle mosfets out, especially in big amplifiers. As mentioned before, broken mosfets do not always cause a short.
I would take them out and test each FET seperately. With this small test curcuit you can find out if all FETs are ok.
When the Fets are out, you can power up the amplifier. Check the gate resistors with a scope. There should be a nice square wave signal. If there´s nothing follow the curcuit lines from the gate resistors. They will usually end at a all-purpose/small signal transistor (usually PNP-type ) Check those transistors´ base with a scope. if there is no square wave signal either the PWM controllers are disabled or burned.
You will then need to take a look at the datasheet and compare it how this thingy is used in your amplifier. Usually the PWM controller IC´s are disabled via the inbuilt error-amplifiers or the shutdown-connector. You can find those in the datasheet. If the PWM-controller is disabled, there might be something wrong in the protection curcuits, or the music-amplifiers have a problem, or both.
Also check, if the RMT-Signal (+12V) is fed through the parts. Usually there is a diode or a resistor around 10-33Ohms in series, those sometimes burn. If so, the PWM controller doesn´t recognize that it´s supposed to turn on.
If you have a square wave signal at the gate-resistors and FETs are ok, install the FETs back into the curcuit board. If you turn the amp on and nothing happens there is a fault in the amplifiers/protectors as the SMPS tries to turn on but is immediaetly shut down by the protection curcuit.
You need to get power to pin 15 of the sg2525. Follow the traces back on the board. The trace may go to a transistor. If so, one leg of the transistor should have +B. The trace may also go back to a diode as sdoom mentioned.
You may want to look at the area where the board was burned. The supply voltage for the switching transistor that supplies power to the sg2525 (assuming that there is a transistor that feeds pin 15) could have been connected to that point .
Until you get voltage to pin 15 of the chip, it wil not turn on and that means that the amp can't turn on.
update- i've traced #15 pin on the pwm's (circuit board out job!) and this is where it leads to. you can just make out where i highlighted the 12v trace in red. on my good amp this is 12v. i think things are starting to get complicated! i've ordered 8 new irfp054's as a matter of course as i think it could be a power supply problem.
the bit that is at the top where the trace is on the underside leads to pin 15. the bit to the left next to the diode doesn't, this is where it gets complicated as it goes through several resisters/diodes and what not!!
good idea to start tracing the remote feed!
