Help needed for My_Ref Fremen Edition , Download folder in Google Drive are not more active
Dear all, I tried to download the Google Drive Folder of the
My_Ref Fremen Edition GB (13th GB) Board.​
But the Folder is forbidden.
I also write to Mr. Fremen, by PN , but unlucky he don´t answer me.
Has anybody of you in this Forum the latest release schematic and PCB and all other Data from his old public link ?
Here the Link of the Post and there is the Goggle drive folder.
The Link for the Google drive you found there direct under the latest THD measuremt diagramm
direct in the first Step of the Topic
https://www.diyaudio.com/community/threads/my_ref-fremen-edition-gb-13th-gb.330082/
kind regards
Michaela
Really , nobody has this ??? unbelivable for this good refferenz Design.
Maybe its a bad Design and nobody used it , or nobody want to help me,
because I was a young girl. I come to thinking about the second reason.
I also ask a known VIP member by PN to Download it for me, because he wrote me, he has access.
But I do not get further help... also from the Maker of this board.
I get the Info that a "Higher" Member get a Reply from the Maker of this Board .
After asking about the Google Drive Folder effect....
I do not get any answer , and ask two times.
This about i was a nobody , or a girl.
I think , they knows, who and what I mean. I do not what tell names here.
This is not fine if VIP Members change informations under themselfs.
And "nobodys" like me get no answer.
Why, because i was a young girl... ? But be sure, I never was unfriendly to anybody....
This makes me very unlucky.... and I think it could be that
"nobody" girls was not suportet here...
Dear
Joseph K,​
yes you are right , now it works..... great !
Thanks for your Tip.
I tried so many times , and it do not works.
Yet it works, today....
Many, many many Thanks....
I was wondering that the VIP´s take care of my hint of google Drive, talk under themself, but
say nothing to me....
So the hint was taken , but the solution to me not...
I do not Found Gerber, but it is still not problem....
I see that this AMP is better as my 2th try...
I start thinking, that I oversized my 4 Layer ground concept.... if this 2 Layer has such much less noise...
So and if I found no Gerber, I will redraw it for my situation and test it vs. my one.
But maybe someone has the Gerber, so I can take it directly... ? Otherwise I pimp it with my ideas into new one
So I make an actuall Design based on Mauro and Fremen for the Year 2022 🙂
LM 3886 ? no problem, I have a lot of original from my Grandpa (R.I.P.) , he was developer
and has quit so much originals from T.I.
So original LM 3886 was absolutely not the Problem... 🙂
For other .... The TDA7293 in composite is also a good Idea.... But totally different in topology.
I has it also made for the Sub with a Subfilter from Mr. Clarsen.... Its sound and perform so great !!
But for normal use they are also good in THD and has the "composite" sound ... 🙂
So if you are interrested in composite Sound and has no LM3886... Google for TDA7293 composite
you will found a good Site of "kal...." My one is similar......
TDA 7293 is a alternativ with good sound and fit for all which have no original LM3886
Joseph K Thanks to you😍
Hi Micha,
yes I was trying to solve your problem but did not say anything because I was not able to actually solve it...glad to read that now you have access.
It's normal that you don't find gerbers, they're not available.
At the beginning and only for a short time beta ones were avaialable.
If you need PCBs I have extra boards from the last GB.
Reactions: tomchr
Hi Micha,
ok,thanks for the Update.... 🙂
