before i start i want to notice :
. I'm french so excuse me for "french sounding" sentences and miss understanding
. I'm a real newbie in hifi, audio, electronic science. The only thing i have ever done is soldering by following schematics, i'm not able to design it.
. I've made a lot of searches before and i ve understood the guidelines but when you talk about TX15465 or other, it's just fully unkown for me. So i need a line to follow because my lack of knowledge let me lost in the forum.
Then i want to give you the background of the project. If I'm going in the wrong way, you'll be able to warn me.
I want to make a caraudio system composed by :
- a source : iRiver iHP140 (mp3 jukebox)
- an amp : axton 4x60wrms
- 2-way speekers : canton QS2.16
As you see i don't want a standard carplayer as a source but only my mp3 player.
My player has an optical line out that i want to use. So the project takes place between player and amp. I'd like to make a DAC associated with a preamp to control the analog output level before the amp.
My needs concerning DAC and preamp :
DAC
. only one digital input (my player output is a optical minijack)
. with only one stereo output
. aimed quality is something homogeneous. I don't want a very expensive DAC with a 300$ audio system (the matter when i read all your DACs projects was i couldn't say if it was very HQ or not, no idea at all !)
PREAMP
. only one analog stereo input
. only one regulated analog stereo output to the amp
. the preamp is the only way i can adjust the sound level
I think that's all so i need a lot of help to know :
. if i didn't say anything totally stupid, if i go in the good way
. if i can make it
. how does it cost, and the way to make it cheaper if it's too expensive
Vincent
DAC
PREAMP
. if i can make it
Vincent
See http://sound.westhost.com/project85.htm for a simple dac and http://sound.westhost.com/project02.htm for a simple preamp. Leave out the parts of the preamp you do not need.
It looks very interesting for me, thanks !
As i said, i'll try my best but i'll maybe ask for some help.
