Help me please ......
I thought you were told it was not a DIY proposition to design and build this 600W SMPS in another thread.
Have you thought about peak current into your loads?
How will your SMPS meet the peak load?
Will the SMPS protect itself?
Will the SMPS protection be audible when it chops off the current demanded by the speaker on transients?
15 A and Vdc +-65 V.
SMPS protect itself when load short circuit.
You have not specified the short circuit current limit.
Do you really think 15Apk is the maximum that a 4ohm (reactive load) will draw when supplied from +-65Vdc?
I don't think you have thought this through.
I believe you have fallen into the usual trap of assuming the maximum power of the amplifier can be satisfied by a power supply of the similar maximum power and ignoring the transient nature of normal signals.
