Help locating C3228 transistor...
Hey guys first post here. I am trying to source some parts for a repair I would like to try. The problem is a blown power supply. I have removed the bad parts(FETs,gate resistors, drive transistors) but I am having trouble locating a few parts. Namely the C3228. It is paired with an A1275 transistor which drive the gate resistors it appears.
For the life of me I can not locate C3228, which I believe to be either 2SC3228 or KTC3228 from what I am reading. But it does not bring up any matches at mouser or digi.
can anyone give me some direction? I would like to replace the with exact matching components and not substitute if possible.
Thanks in advance
I found the 2SC3228 data sheet myself. That was not a problem I just wanted to make sure what they had and what I was finding were the same. As 2SC3228Y is more expensive, but has no data sheet that I can find. When I search it it takes me to the 2sc3228 data sheet.
I just wanted to confirm my thoughts before taking actions.
But thank you for your help.
So. I ordered the transistors with no data sheet from the site. They show up and what do ya know they aren't the same ones🙁 They have the right part number but they are different then my originals. And they differ in shape from the data sheets I found. So I'm back to square one....I'm gonna try and find data on these and see if they will work.
Well guys I thought I would post a couple pictures of the 2 transistors I have....First one is the one I am looking for. It is an NPN BJT drive transistor in the power supply section of this amp. It is square in shape with beveled sides and flat back.
The ones I ordered are the same number C3228 but have a different shape like this...
There are lots of companies that make the same numbered parts and some of those companies might simply use a slightly different shape of transistor than other companies ......
If you look up many datasheets for a part number there might be 5 different companies making the same part and they look slightly different ......
Cheers
So I have found. But that is not the cas here. I believe the part I am oooking for is in fact KTC3228 which is a KEC brand transistor. But I have found it to be obsolete. Or at least discontinued. So I am looking for NOS C3228 transistors I guess. I am learning as I go. But it seems very in depth. Thanks fo all the help guys!
I understand. In my search I came upon 2sc3228 which I thought to be the same component I needed. But when in fact it is KTC3228 that I have. When I search that data sheet it brings up the same shape trandistor I have. But I have found some with 2sc prefix and KEC shape. So I am confused a bit. But I am in talks with a couple people in locating what I need.
Again I am new to this so please understamd.
I understand what you are saying but what im trying to get across is that internally a KTC3228 and a 2sc3228 are the same and have the exact same specs for the most part ...... They are the same transistor internally but have a slightly different package .....
Much like when you go to shell and get gas it is the same gas you would get from chevron , or buying a mufler from Mopar or from GM , They are pretty much the same product in a different package .......
You could theoreticly use any transistor with a simular voltage and HFE rating and the curcuit would work .......
