help in installing a preamp in my diy mixer
hey everybody,
so a while a go i made this little passive mixer for mixing 2 guitars together.
the guitar signal first goed trough a 10k resistor, then a 10k potmeter for volume. it works fine when plugged into a guitar amp. But i would like to be able to plug this little mixer into a regular line level amplifier. So my idea is to add preamp, boosting the signal up enough to be able to play trought a normal speaker at loud volumes.
so does anyone have an idea what kind of preamp to use, and what to look out for? thanks in advance🙂
oke guys, i have assembled my stompbox mixer, here's how it looks(still needs a paintjob) it feutures 3 inputs and one piezo-guitarpreamp footdrum thingy, going through the little bear amp, and to the output.
Imgur: The most awesome images on the Internet
it works works quite well, but i still have a problem. when stomp on the piezo, it gives a pretty nice kick-sound. however when i turn it up and kick it, it shuts down my speaker amp(ta2024). though it doesnt even sound that loud. my guitar sounds way louder. i'm guessing the signal is to strong, and the amp goes into protection. anyone have a sollution for this? will a passive compressor/limiter circuit maybe help?
