hi -
i have 2 telefunken tubes where the writing is all but gone. one was in a box hand labeled ecc85, but many tubes from this batch were in improperly labeled boxes, so i don't feel comfortable relying on that. pins 4+5 and 4+9 have continuity. the plates are smooth and have the same length, but appear slightly different as far as the side holes are concerned. (see details on image links below)
i have uploaded a set of pictures of each to photobucket here:
telefunken nr 1 pictures by langlieger - Photobucket
and here:
telefunken nr 2 pictures by langlieger - Photobucket
if i can be sure they are safe to try as an ecc83/12ax7 type that would help. i just feel to unsafe to stick them in an amp and try, since i don't know the expected heater voltages.
any tips would be greatly appreciated -
chris
and here:
chris
