Help Identifying emitter lead for NPN Trans
I have a 2N222a NPN transitor TO-18 package made by STMicro. When looking at the data sheet it I think I'm able to discern the three pins (emitter 3, base 1, collector 2) with the emitter 3 pin directly to the right of the metal tab. But on the transistor case there is an e3 circled by the pin that looks like the collector on the datasheet! Can anyone set me straight!
Datasheet
http://www.st.com/stonline/books/pdf/docs/9288.pdf
