Help identify 3.5mm connector
Browsing in a paper or pdf Digikey catalog might find something. I'm sure I found an old pdf online a while back, but it's not showing up for me now. Anyway, you can also browse their online listings and drill down by restricting it to 3.5mm, through hole, etc. Here's one I found that has some similarities:
https://www.digikey.com/en/products/detail/schurter-inc/4832-2330/2646633
It's possible that Sony used the same jack in other things; it doesn't look too different from the green jacks that were a common problem in '80s Sony products.
