help for tl072. distortion occured when pot volume increasing
Distortion occurred when pot volume increasing and also continuous thumb bass
kindly anybody advise for this problem.i have attached the schematic with this
A guess: You are loading your first OPAMP too hard with only 1K (R1). Perhaps also the second OPAMP depending on the impedance after the potentiometer.
NB: According to your schematic you have "+" on both supply terminals.
The circuit is electrically OK at a basic level, its more a question of what you need it to do. The first opamp stage has a gain of almost -1 and so its contribution is minimal.
The second stage has a response like this, and 20db gain at the high point which is a lot.
