Hello!
Anyone has the drawing of Linn LP12 plinth to share?
Thanks!
Why not just measure one? 😕 The #1 critical dimension is the front-to-back distance on the inside of the plinth ... so the top-plate will fit snugly.
The #2 critical dimension - which is not quite so critical - is the side-to-side distance inside the plinth ... so the armboard fits between the end of the top-plate and the R side of the plinth ... and there's a suitable gap on each side of the armboard.
Re. height - if you're contemplsating making one, i suggest it would be advantageous to make it 100m high.
Andy
Hello!
Thanks!
If you're patient, I can do a drawing for you.
jeff
jeff
Dear Jeff,
Yes, I'm waiting and really appreciate for that 🙂
Many thanks!
