Hey guys
I am having no luck finding 1/2 inch wool felt
for CC dampening any ideas where to find it,
I know Scottmoose recomends this stuff
a lot. just no luck finding it.
Hi
I can't say about your guys in the US, but I found it at an automotive re-upholsterer up here in the frozen wastelands of Canada. Ask for automotive carpet underlay. They had two kinds here- just make sure he understands it's the wool felt type you're after.
The best part is it's dirt cheap.
Kevin
Kevin
I found it at a high end flooring and carpet dealer. They called it jute padding but it was wool felt, symantics I guess. It comes in different sizes and only cost me $30.00 for a large piece. Was enough to sound proof a '67 VW,top and bottom, and four speaker projects.
Dan
Dan
My source is McMaster-Carr , just type "F-13 " in the search box and you'll be in wool felt heaven 😀
Be sure to type a space after the "13".
I have a friend that felts old sweaters and uses the material for mittens, bags, etc. It's a well-known technique in the craft hobby world, and you'll find plenty of info out there if you search for it. Basically you wash in very hot water and the fibers entangle into a medium-dense felt up to 1/2" thick as the sweater shrinks to half its size.
Since you can buy a sweater at a thrift store or rummage sale for just a few bucks, this is definitely the cheap way to go.
--Buckapound
--Buckapound
Buckapound said:Basically you wash in very hot water and the fibers entangle into a medium-dense felt up to 1/2" thick as the sweater shrinks to half its size.
& add a few drops of liquid soap to the hot water.
rub together & the wool mats together.
You can get raw wool from a local fiber arts co-op here, big bag is real cheap, can make as thick or thin as you wish.
- Full Range
- Help finding 1/2 inch wool felt ?
