Help! Dynaco FM3 heater choke
I recently acquired a Dynaco FM3 through the internet.
Last night, while re-checking the V2 tube and then replacing its tube
shield I inadvertantly left the shield in contact with L5 heater
choke. When I turned the tuner on, there was a short, of course, and I
got smoke from the choke which now is quite charred.
What I need to know is, how can I replace the choke? Are original
replacements are available, or at least a generic substitute? The FM3 uses 5 or 6 of these things. The schematic doesn't give a value for it.
Thanks for any help you can provide.
Bill Gallagher
Hi Bill
If the choke is in series with heater value woldn´t be too critical. I have the kit manual so i´ll read through and see if value is mentioned, otherwise You could meassure one of the others and buy a standard taking heater current into consideration.
Hi, Ingvar,
Thanks for your reply. Please understand you are talking to a novice. I'm not sure how to determine whether the choke is in series with heater values. Does it refer to the heater value of the V2 tube? I also have the kit manual and found no reference in int to the value. It appears that these heater chokes - L2 through 25 - are all the same. There is no reference to the kit builder installing them on the board, so I assume they came already installed. I am not sure how to measure the value of such a component. What value would it be in? I read something about milihenries, which I have no idea what unit this would be. Nor would I know where to buy a "standard" or how to "take heater current into consideration. I'm afraid someone with patience would have to walk me through the process.
Kind regards,
Bill
Hi Bill
Ok Bill, i´ll look through what info i´ve got on the choke.What You should measure is inductance, that´s the (milli) Henry figure quoted. Not easily done without special instruments.
Are You shure there is anything wrong withe the choke, other than looks. The short would cause a spark, some smoke and a bit of smell but not neceserealy destroy anything. Did You try the tuner after "accident". If not, do, nothing will break even if the choke is faulty.
I have been corresponding with a person who has 4 of these coils from a disassembled FM3 and who will sell them to me for $10 dollars for the four. Sounds pretty reasonable to me. I assume that all 4 are the same value. The FM3 has several heater coils, L1 through L5, I believe.
What do you think?
Sounds reasonable as they are original, a new would be a buck but it would be hard to find exactly the same as a stock product.
All are same value wich is not critical, somewhere around 10mH @ 500mA would surely work, they are there to prevent hf/mf interference as a filter together withc34-c38. The original will look better.
