Can anyone identify the manufacturer and/or model of this horn tweeter?
Magnet diameter 70mm
SPL: 102dB @ 1W/1m
Impedance: 8 ohms
Frequency range: 3.5K-20KHz
Recommended crossover: 4KHz
Maximum power handling: 120W
Nominal power rating: 45W
Diaphragm diameter: 70mm
Horn body: diecast aluminum
Mounting plate: plastic
Baffle opening: 71-80mm
Screw hole center-to-center diameter 100mm
Weight: 690g
THANKS!
Christopher Witmer
SPL: 102dB @ 1W/1m
Impedance: 8 ohms
Weight: 690g
THANKS!
Christopher Witmer
