hi, i bought 2 lilliput 4", they work for 1 day and now they didn't turn on.
what could i check with my tester ? and how ?
the voltage at the extrimity of the fuse is 12 volt and there are no visible exploded condensor.
pls.....help me
pls.....help me
hi
did you buy it new, if so take it back to the shop, get it replced, what spec is the LCD,
SAfe
SAfe
sup dude, check the ribbons are in teh slots, sometimes they can be loose, apart from that email them and say its faulty, did you rip the sticker on the side of it????????
safe
safe
the ribbon is ok, and the sticker on the side is broken.
i'm sure it's a power problem, but i don't know the esactly broken component.
The repair man man man man
okay were going to have to work together on this one. It's going to be hard, but if we stick together we could do this. First locate you lilly. Then find trhe mogulator. Then look at that orange thing on it thats the problem. Were going to need to install a thingamabobber to off set the orange thing. Then loacate your specturum, and just pull it out. even if it dosent want to give hmkay. Now that shoud do the trick. No thanks needed just doing my job.
Re: The repair man man man man
thank for help, but probably my english is too bad to understand.
lilly = ?
mogulator = modulator ?
thingamabobber = ?
hmkay = ?
please.....explane me and i'll be debtor to you for ever 🙂
dengez said:okay were going to have to work together on this one. It's going to be hard, but if we stick together we could do this. First locate you lilly. Then find trhe mogulator. Then look at that orange thing on it thats the problem. Were going to need to install a thingamabobber to off set the orange thing. Then loacate your specturum, and just pull it out. even if it dosent want to give hmkay. Now that shoud do the trick. No thanks needed just doing my job.
lilly = ?
thingamabobber = ?
hmkay = ?
- General Interest
- Everything Else
- The Moving Image
- LCD
- [help] broken lilliput 4"
