help a newbie build his first tube project
hi all .
i m trying to build a marshal 50w amp w an ecc83 and two el34 with help of u guys in here ,..
it s my first tube project , and i wanna use this amp w an ampeg v3 bass preamp ,...
i just don want to fail in this project and loose everything , so i m tryin to go on step by step w help of you guys ...
thnx ...
here s the schematic of marshall amp :
http://www.drtube.com/schematics/marshall/78331-2.gif
and the ampeg preamp :
http://www.drtube.com/schematics/ampeg/v3pre-jp.gif
i have a few questions before starting buying stuffs ,
1-wat can i use as choke in amp ? can i use any choke ? or i should wound a choke ?
2-wat exactly transformer i need to use for pre and power amp supply ? how much ampere shoud the transformer have ? i already have a transformer w 250-0-6 secondaries , can i use it for this amp ? or if not and i should wound a transformer wat transformer i exactly need for supply ?
hii Bas , glad to c u here 🙂
thnx man i cant go on and take everything from you 😛 . i think 10 to 20 turns of #22 insulated wire on a .5 cm guage air core will do the job for me yeah ? or do i need a core ?
wat bout power transformer ? wat transformer i exactly need ?
can i use my old 250-0-6 transformer ? or i should order a transformer w 350-0-350 and 6 , secondaries ? ( how much ampere ? )
Order the right part for the job- i.e. get a new transformer. Buy a proper choke as well- they are very difficult to get right, otherwise they buzz like crazy.
You might want to consider buying a kit with all the parts you need- it works out a lot easier.
Also be sure to read the
Safety Thread
And yes there are people out here, so no need to yell...
Hallo Ahmad,
Yes, you would need a core...since most chokes for a tube amp I have ever seen used a core....you could wind an air core..but I think you can't get usefull H out of that.
One thing is that the core must have an airgap....because it has to pass DC (or part DC) ..So it will look a little like a single ended output transformer.
But like I said..I'll mail you a choke.... 🙂
I'm picking up the transformer tomorrow and will post some pics.
Regards,
Bas
