Welcome to diyAudio :^)
I can’t argue with your choice. I just shipped a se toff to ON.
I do need to get that properly drawn.
What amplifier do you plan to use?
dave
dave
Well I was planning to build a pair of Frugel-Horns, but I discovered they are corner loaded and I could not guarantee that I could put them in corners. I had read a comment by you that those speakers have the potential for good bass due to the greater excursion, they also had a very interesting cabinet design. Part of this whole exercise is I wanted to build an interesting cabinet. And that was that.I can’t argue with your choice.
Except for some low Q drivers like FE166/168 near a wall is all that is required.
Not using corners typically means less damping required.
dave
dave
