Hi ale3hs,
Welcome to diyaudio!
I'm sure you will find more than enough around here to keep you building something!
-Chris
-Chris
I am starting my own little diy project.
Hello and welcome to the forums. You call building the Nautilus a little project? You are very adventurous my friend. Please keep us informed of the progress and don't forget pictures.
Absolutely! indeed it is adventurous i'm trying to finish off the design in such a way that it will make the implementation as painful as possible. I should be starting within the next month. The only problem being the lack of a good metal dome tweeter with a small magnet to fit the 1" hopefully I can get some recommendations here as I haven't really found anything from all the usual driver manufacturers.
br
