Hello from Latvia!
Hi all!
My name is Andrew, I' 17. I live in Riga, Latvia. I always wanted a high-end audio system, but couldn't afford it. Which is normal I think. I didn't want to get along with low or mid class audio equipment, because I can't stand the sound distortion in the music I listen. And I listen to old school rock, such band as AC/DC, Guns'n'Roses, Metallica. But Iron Maiden is my #1. I already own a pair of DIY l-speakers, but not made by me though. While browsing the web for apropriate amp for my loudspeakres I found diyaudio.com.. I didn't realize that you could make a amp in household conditions. I was amazed.. I thought, that maybe I could find help building my first-ever project - a splitter/mixer.
Thank you if you read this!
Welcome. If you're keen enough, you can make anything at home. By the time I was your age, I had made a pick-up arm (for playing vinyl), pre-amplifier and power amplifier, loudspeaker (mono - couldn't afford stereo) and electrostatic headphones. I also had solder splashes all over my bedroom carpet...
Go for it!
