I have just finished building a rack mounted all tube EQ prototype. One channel is a Pultec like passive EQ but with an added mid cut section. The other channel is a tube version of the classic Helios Type 69 passive EQ. here are a few pics:
Cheers
Ian
Cheers
Ian
Ian, what's the reason for the bigger input transformer? Looks like a 1:10. If it isn't a preamp as well, won't it be fed from a line level signal? Or does it benefit in other ways?
Charlie
Charlie
Charlie
The bigger transformer is the output transformer - it is a 1:1 (600:600) type. The smaller transformer is the input transformer - it is a 1:1 (10K:10K) bridging type.
Cheers
Ian
Cheers
Ian
Do you have a schematic? I would be interested in looking at the design.
Pultec EQP1A Equalizer - Pro Audio Equipment DIY - DIY Vintage Pultec (Pulse Technologies) EQP1A Program EqualizerDo you have a schematic? I would be interested in looking at the design.
Here is the schematic of the Pultec part. It is somewhat modified from the original to allow the use of a 10K:10K bridging input transformer rather than the original 600:600 type plus mods to accommodate the additional mid cut.
Cheers
Ian
That is what exactly i was searching to include in the tube preamplifier which i will build as a companion of the SET monoblock power amplifiers.
Excellent work Ian! That is exactly what i like, a well documented and focused design. Very nice built! I will be in contact with you - if you allow me - for any technical advice in the near future.
Thank you in advance.
Fotis
Fotis
Fotis
Thanks for the kind words. It is always nice to know tyour efforts are appreciated. The design has pregressed quite a lot from this early prototype.I now have PCBs for the Pultec and Helios EQs available if you are interested. You can find further details here:
Index of /EzTubeMixer/docs/EzTubeMixer/Helios69EQ
and here:
Index of /EzTubeMixer/docs/EzTubeMixer/3BandPultec
PCB prices and on overview of the projects is here:
http://www.ianbell.ukfsn.org/EzTubeMixer/
Cheers
Ian
- Live Sound
- Instruments and Amps
- Helios + Pultec tube EQ rack prototype.
