Heathkit IG - 37 Stereo Gen
I have a very nice Heathkit IG - 37 for sale. This unit works fine and comes with a very nice factory manual, plus both factory cables. The very hard to find 300 Ohm twin lead connector that plugs into the front of the unit is included. The 300 Ohm twin lead still has the factory alligator test clip setup, that connects to the tuner's external antenna posts also. Price is 125.00 US dollars, plus all shipping/tax costs to your doorstep. No Paypal. TIA
From the nostalgickitscentral web site:
IG-37 FM Stereo Generator for RF, IF and FM Stereo Alignment.
Produces virtually all signals for trouble-shooting and aligning multiplex adapters, FM tuners and receivers. Generates mono FM or composite stereo FM signals.
Crystal-controlled 19 kHz (plus or minus 2 Hz)pilot signal, adjustable from 0 to 10% for checking tuner lock-in range.
Switch selection of 400, 1000, 5000 Hz, 19 kHz, and 65 or 67 kHz SCA signals.
100 mHz sweep generator, adjustable plus or minus 2 mHz, for overall RF and IF alignment.
Built-in crystal marker oscillator for IF and dual-tracking checks.
Phase test capability.
No balance adjustment needed for equal Right and Left channel modulation levels.
