Heater Transformer Hum
I am working on a project using 866ax rectifiers. I have a 5V 15A transformer running the heaters for the above. I am getting fairly loud mechanical hum from the heater transformer. I haven't put it in a chassis yet so it may quiet down a bit once finalized. The amp seems to be working fine but the mechanical hum is somewhat disturbing. I can buy a smaller transformer as Hammond has a 5V 8A unit but I hate to just run out and buy more stuff just to try. I am wiring the tubes in series and pulling my B+ off the center tap. Any thoughts as how I might quiet things down? Amp is quiet through the speakers. I do have a 5V 3A unit but I am afraid to try that even for a few minutes.
TIA
First try tightening the bolts, don't go mad though. If that doesn't work try taking the bolts out,power up then dribble some thinned varnish between the laminations. Power off, bolts back in and tightened,allow to dry overnight. You can put your tfmr in the oven to warm up prior to applying varnish to improve the varnish impregnation.
It could be it's under-wound, IE not enough primary turns. It's an idea to measure no load primary current, it should be about 3 - 5% of it's max loaded rating.
Andy.
Just do not get an AM radio next to the 866 power supply.
Buzzzzz.
With really good quality choke, and no input cap until after the choke, that might not interfere with the AM radio.
Your mileage may vary.
On the heater just like when using a transformer. The SMPS must be isolated (and rated for at least B+ voltage - most are rated at at least 2kV so no problems) as B+ will appear on the 5V output of the SMPS. You can think of it like using a 5V battery to light up the tube.
