Head-amp PS question
When you have these one (or two) transistor solutions you must have a very very quite supply voltage. I can see only one problem (maybe) that the transformer introduce hum via capacitive coupling but it's no harm in testing.
EDIT: Oh I forgot, you probably add 1000-10000 uF in decoupling plus 100 nF after the wall-wart but add also 1-100 ohms in series. By this you create a LP-filter. It's possible the wall-wart deoesn't like to much caps at the output..
Ok, Thanks for your help Peranders and SY. I'll make the head amp so it can be powered from either a battery or a wallwart-based regulated supply. That way the battery will work fine until (if ever) I get adequate results from the wall wart.
Joseph.
