HDMI i2S output from SATA to i2S board
Hi , I am using your Sata board in my cd transport and it does an excellent job over SPIDF. I would like to use the I2S output from the board with my I2S input AK4495SEQ DAC.
I understand that your I2S over Hdmi is the same as PS audio format but differs from the Audio-gd and Aune Hdmi-i2S input boards in the way that the LVDS input/output is wired.
Do you make a simple Hdmi-I2S board that can receive the the LVDS signals in PS audios format or can you suggest an alternative module that will do the job.
Thanks in Advance,
Gordon
