Hello. Accidently I burnt the left driver (bobbin) of my Sennheiser HD 650. Where can I buy the spare part at a good price? Or if there is someone who owns a inused/broken identical one, that would be welcome...I live in Italy.
May want to check with the Sennheiser company. Don't know how available repair is where you are located, but their repairs I had in the past were pretty reasonable.
Regards, Greg
Regards, Greg
Please look for your country distributor, here in Spain no problems with Magnetron distributor:
Magnetron - Solo el Mejor Sonido
Merlin, I took a look to the site but I don't see the spare parts for my item..in any case I wrote them.
As for restoration, I fear it's hard thing. By an accident a 100Vac "flying" wire fell into the left channel (through the jack input) so the bobbin's thin wire was burnt and also the diaphragm was punctured. In misfortune I'm lucky the hv wire didn't touch the other channel
See here, the drivers are there, about 130 Euro for a pair. I wonder if they can be matched. Don’t buy only one, many variations of this driver was done, the newer one are apparently less veiled.
Sennheiser HD650 headphone spare parts - Sennheiser Pro Spares - Purchase Online
BR
Eric
BR
Eric
Thanks fortier, yes I had seen this and I already contacted the Sennheiser store...my idea is to buy just one, because I bought 2 years ago and payed 200€ sp don't want to spend too much for it.
I read in a forum that substantially HD650 drivers should be made all with same characteristics and I don't think they must be necessairly matched. So meantime I could buy just one and then see how it works. If I note some differences then I'll buy another one (shipping cost is cheap).
Sounds good
An alternative would be to find a pair of Massdrop-Sennheiser HD6xx, it is apparently exactly the same as HD650 (sounds wise)
BR,
Eric
BR,
Eric
The Spanish distributor told me the same: not necessary to be matched because manufacturer uses tight specs.
Arrived today the left driver replacement for the headphone. After installing it I tried it and noticed not advisable difference with the other, anyway I began to run a wav burn-in file to the left channel only.
Someone can suggest me a good file for that? The one I found and I'm using is on Jlabaudio...
Ciao, potresti dirmi dove l'hai comprato il driver? Io non riesco a trovarlo da nessuna parte. Dove hai contattato Sennheiser per chiedergli il pezzo?
Quanto costa un driver? e quanto tempo ci mette ad arrivare?
Grazie mille
Grazie mille
Grazie mille
Hi, could you tell me where you bought the driver? I can't find him anywhere. Where did you contact Sennheiser to ask him for the piece?
How much does a driver cost? and how long does it take to get there?
Thank you very much
