Has anyone rear ported the GM MLTL 48 ?
I'm having trouble sourcing locally a good looking 50mm port. I can find one with a large flat lip and 4 big screw holes, but if I go with this one I would prefer to rear mount out of sight.
So, has anyone done comparisons of rear versus front porting on this design ? I see Jim Griffin uses the rear port on his ribbon tweeter version, can I assume similar results with the "standard" MLTL 48.
Thanks,
Dan
Gary,
I'm in Wellington, thanks for the offer.
They need to be 70mm in length - can you confirm measurements ? I ordered some locally almost 3 weeks ago but am still waiting (wrong size sent initially and no sign of the correct ones since...) They are the only things holding me up finishing my build, so am considering rear porting using Jaycay items as per this thread.
Dan
