Has any made a speaker from a Stainless Steel Sphere?
Orb audio also use them.
Orb Audio | Orb Audio: Small Speakers For Smart People
Once you have chopped the hole for the drive you will have to figure out how to attach it, you may be able to peen it over to form a flange or bond on a wooden ring (two halves fitting inside to keep it clean), you may also want to line the inside with the acoustic bitumen use in cars.
Two industrial mixing bowls may also work and have a flat for the speaker already, 20l and 25l are available if you need big volumes.
The 28cm sphere has a volume of 11.5l and you will loose a lot of that cutting the flat and the volume of the driver so probably down to 6 or 7l.
Just a couple of thoughts.
