Harmony guitar amp restoration questions
Im Doctoring up my Harmony H304 amp. I tested all the tubes and they are good and the amp works just a lil' bit crusty sounding.
Thought I would start with Caps. So here are my questions:
1. The schematic doesn't specify using polarized caps. Thoughts on this especially the filter caps. And where to use electrolytic and poly.
2. Can I substitute 3- 20uf caps in place of the stock "can"?
3. Should I remove the cap on the Power transformer? (C9) possible death cap???????
Any help with above questions and tips or things to look out for would be appreciated.
Thanks!!!!
Here's the schematic.
weird noises in an old harmony tube amp - Telecaster Guitar Forum
C's 5-8 and 10 are all conventional electrolytics.
Of course.
That's usually done along with the three-prong cord conversion.
Do not underestimate the power of cleaning. A can of Caig D5 and a toothbrush will cure a lot of ills.
